C5 408 turbo cranks will not fire, has spark and fuel
Hey guys, need help asap, I'm in Texas for the roll racing which starts in 10hrs. Upon tuning my boost curve it was rich so I let out of it, car backfired and I pulled over to reflash. Car died at idle, then the car would not start. It cranks and cranks and cranks, but will only pop or backfire once or twice and that's it. Changed plugs as they were fouled. Still no start. Has fuel, has spark, (verified both), has 160-165 compression on all cyls. Changed crank sensor, and cam sensor. Has 2 cam sensor codes after the pull. Is the culprit a skipped timing chain? (Has a double roller on it with less than 500miles) car is a 408 lq4 single 88mm turbo in a c5 tuned with hp tuners.
Really stumped as it worked perfect in canada when I tuned it, and the air is just so much different here than in canada.
