Idle hunt/dip on coast
Generally idle instability is caused by over rich condition.
If you look at the timing when the idle dips, it's stable @ 20*. Go to your main timing table & copy the 400rpm column into your idle 0 & 400rpm idle timing table columns. This will act as under speed idle timing, because it has not gone into adaptive idle as you are rolling.
