Fans do not come on with A/C
I think this all started happening when I did a cam swap/DOD delete a few months ago. I had a tune loaded into the car at the same time. I do not know anything about the tune, where it came from, etc. The noise started immediately after the cam install though I'm not sure about the warm air/cool air part because it was winter.
I am thinking something in the tune is keeping the fans from turning on when the A/C pressure ramps up. I suspect this may have damaged my compressor as it now makes a louder than acceptable groaning/growling sound. How do I figure this out? I have an HPtuners copy of my tune but I really don't know what I am looking at.
The car is a 2009 G8 GT.
Thanks in advance!
**One more thing - my A/C compressor is clutchless. It is always engaged and the pressure is ramped up and ramped down by a variable valve/solenoid in the rear of the unit.***
Also, I will get a set of AC gauges on it this weekend. There is a chance that the system is low on refrigerant and the compressor noise is the compressor pulling vacuum. Not the best theory but I'm running out of theories here!
