Histogram Filter string hptuners
Old Apr 8, 2016 | 10:33 AM
maroonls1z's Avatar
Default Histogram Filter string hptuners
Im looking for some help with setting up filter strings for histograms. Specifically i would like to set up on for my stft so that it does not fill in a cell until the throttle has not been changing for a couple seconds so that i get more stable data. The instructions in the "help" section could use some expansion
Old Apr 8, 2016 | 08:54 PM
rpturbo's Avatar
What version are you using, 2.24 or 3.0? Sounds like you need to do some filtering.
Old Apr 9, 2016 | 05:27 AM
maroonls1z's Avatar
Running 2.24. I would ideally wat to set it up so it said exclude values that had a change in throttle position within the last second. I figure someone has to have done this and i know efi live has tps rate of change < x. Dont know how to set that up in hp
