Siemens 60lb Injectors
Old Apr 10, 2016 | 03:06 PM
455GTO's Avatar
Default Siemens 60lb Injectors
I picked up a set of Siemens 60lb injectors after maxing out my FAST 36lbers on my 403". From reading it looks like all i need to modify is the IFR table in the tune. Anyone have experiece with these or know what data is needed in the other tables?
Thanks
Old Apr 11, 2016 | 09:59 AM
455GTO's Avatar
Anyone have these?
Old Apr 12, 2016 | 11:50 AM
Chevy406's Avatar
There are 7 different tables that you should adjust for the specific injector you use. You didn't mention what Operating System you are using, but I've gone ahead and attached a 2001 Corvette tune with 60# Siemens flow values.
File Type: hpt
Old Apr 12, 2016 | 02:21 PM
455GTO's Avatar
Thanks so much! Sent a pm to clarify if this is correct for my 2002 Trans Am.
Old Apr 12, 2016 | 04:13 PM
JakeFusion's Avatar
Super Hulk Smash
It will be the same. You're on a Gen 3 PCM as is the 01 Vette.
Old Apr 12, 2016 | 05:37 PM
455GTO's Avatar
Awesome, thanks guys. Learning as I go with the tuning and couldnt find anything set it stone for data on these.
Old Apr 12, 2016 | 09:29 PM
JakeFusion's Avatar
Super Hulk Smash
Did you convert that data from the Ford/Banish info?
Old Apr 12, 2016 | 10:05 PM
Chevy406's Avatar
I don't know where that 60lb injector flow data originated from. I've used it for several cars with 60 lb Deka injectors.
Old Apr 13, 2016 | 04:19 PM
JakeFusion's Avatar
Super Hulk Smash
It seems different than the converted Ford stuff. But if it works, then it's all good. VE table looked good in that tune.
Old Apr 15, 2016 | 11:58 PM
455GTO's Avatar
Copied those injector tables and the car fired right up and ran great. Thanks again for the help!
Old Apr 16, 2016 | 12:55 AM
455GTO's Avatar
Only issue ive been fighting is the car pops and gargles when first flooring it and then it clears up and pulls hard. It goes pig rich when first flooring it.
Old Apr 17, 2016 | 10:38 AM
DMM's Avatar
DMM
What is your fuel pressure? If it's stock, the injector data posted is way, way off. Injectors rated at 60lb/hour at 30 PSI do not still flow 60lb/hour at 58 PSI.
Old Apr 17, 2016 | 11:31 AM
JakeFusion's Avatar
Super Hulk Smash
The data converted from Ford is in this file. It's different. Try this.
Change Flow Rate, Offset vs., Short Pulse, Min Inj, and Default under Fuel>General to the values seen here.
File Type: hpt
Old Apr 17, 2016 | 10:33 PM
irrational's Avatar
would you also happen to have injector data for 80lb seimens deka IV injectors?
Old Apr 18, 2016 | 12:06 AM
455GTO's Avatar
Thanks Jake, so your file will be better for the stock 58psi fuel pressure? It so, ill copy all the tables and see how it runs
Old Apr 18, 2016 | 07:32 PM
JakeFusion's Avatar
Super Hulk Smash
Sure. Same as above on what to change.
File Type: hpt
Old Apr 22, 2016 | 09:27 PM
455GTO's Avatar
Just uploaded the data you provided Jake and wow what a difference!!! The car runs so much better and doest gargle lean when going WOT. Thanks again!
Old Apr 23, 2016 | 12:33 AM
JakeFusion's Avatar
Super Hulk Smash
If you have any issues, take the min fuel mg in transient down to .016 or so. That'll help with those injectors at idle.
Old Mar 17, 2018 | 11:37 AM
jandylee070601's Avatar
Default data
Can you email me this, it wont let me open it, thanks
jandy_phillips@yahoo.com
Old Mar 17, 2018 | 05:31 PM
rpturbo's Avatar
I could not open this tune either for some reason.
