Help 2002 A4 starts then stalls.
Old Apr 10, 2016 | 04:07 PM
corvet786c's Avatar
Default Help 2002 A4 starts then stalls.
Couple of days ago car running strong 2002 procharged A4. Then all of a sudden it buckles some and catches its breath. Now it's cooler temps outside here and this morning I try to start it up then 2-3 seconds it slowly dies. I have fuel pressure hear fuel pump and fuel guage reading 50-55 psi, no codes, I can't think of what else it could be. Any thoughts?
I just wanted to add that the problem first started driving around town all the gauges seemed normal them just driving noticed a sputter and like it wanted to die, but made it home in time, Now this morning, it starts, but slowly dies.
I did recently remove plugs and wires, but made sure carefully to hear click when putting them back on.
Old Apr 10, 2016 | 08:14 PM
Old Geezer's Avatar
Try the forum for tune/diagnostics......
Old Apr 12, 2016 | 11:54 AM
Chevy406's Avatar
Fuel pressure should hold constant 58 psig at idle. If it's dropping to 50 psi then that's your problem.
Old Apr 13, 2016 | 07:52 AM
corvet786c's Avatar
Thanks for the reply, I forgot to plug in the MAF sensor, problem solved. Fuel pressure still holds 60psi @ idle. Thanks again.
