Startup fueling
Old Apr 21, 2016 | 08:25 PM
wht97ws6ta's Avatar
Default Startup fueling
Hey guys just thought I would see if anyone has had similar issues as im having and can steer me in the right direction. I have a 97 355 lt1 with efi connections 24x setup. The problem that im struggling with is the first startup being to rich. It will bust off like a champ, run for a couple of seconds and cut off. If i crank it with the throttle slightly cracked its fine. I can keep the throttle cracked for about 10 seconds and then it will idle on its on. I have hp tuners and havent found exactly where i need to be to make the correct changes. I dont really want to just start guessing at it until i find it and have to fix what didnt make a change for the good. It still does it when its up to temperature but it will idle at 500 rpms or so for a bit then it will start to find its way to a decent idle speed.
Old Apr 26, 2016 | 03:57 AM
natejk's Avatar
post up a tune file
