Injector Data Sticky
Old Jul 11, 2019 | 10:58 AM
  #61
JakeFusion's Avatar
Super Hulk Smash
Yeah, that looks better.
Go go gadget imperial!
Old Jul 11, 2019 | 11:21 AM
  #62
AINT SKEERED's Avatar
I dont see the transient wall table in my operating system.
I changed the rest .wont actually be changing injectors for a while until my transmission is in and all good.
Old Aug 18, 2019 | 03:33 AM
  #63
fastsspr's Avatar
Hello, any data for FIC Simmens 72lbs ?
Thanks in advance
Old Mar 26, 2020 | 01:41 PM
  #64
agrant40475's Avatar
I have 03 Silverado with a stock FPR on the rail. What would I use for the IFR and offset when using the Deka 80 data? I'm assuming the IFR would be the same all the way across but when logging fuel pressure, pressure changes under vacuum. Thanks
Old May 14, 2020 | 05:33 PM
  #65
DK's Avatar
DK
Probably the single biggest issue with a new tune is good injector data. I'll post what I have here.
By any chance, do you have the data for 2001 C5 LS1?
bosch 02801 55931 (12482704,12533952)
ive looked aroun in hpt but havent found the dead times yet.
Thank you in advance!
Old May 17, 2020 | 04:11 PM
  #66
mrvedit's Avatar
Moderator
A stock tune for the 2001 C5 is available in the HPT Tune Repository. Log into hptuners.com, click on your name for account info and you will see "Tune Repository" on the left side.
Old Sep 18, 2020 | 08:44 AM
  #67
17outs's Avatar
Anyone have values for 12561462 for holley term x?
Old Jan 4, 2021 | 05:33 PM
  #68
Gripenfelter's Avatar
Anyone have data for Bosch 30# injectors? Orange body and says 9186340 on the side.
Old Jul 26, 2021 | 05:38 PM
  #69
kyoytey1693's Avatar
I'm looking for the Fuel to Wall data for some 365cc FIC (Clinic) injectors. I know it's usually left stock but I would like to see it for comparison if anyone has it. It's not on their website.
Old Dec 22, 2021 | 10:48 PM
  #70
LilJayV10's Avatar
Anyone have the data for ID1000's, 4 bar, return style system.
I used the info off their site, but I think I might be missing something as far as minimum pulse width or something. My VE is really really low at near idle and I still can't get it leaned out enough.
Thanks.
Old Dec 27, 2021 | 05:06 PM
  #71
mrvedit's Avatar
Moderator
Thanks.
Please give us more info:
What is your fuel pressure?
What size engine and cam is this? Turbo or supercharged?
What is your VE near idle?
What is your pulse width at idle?
What symptom and measurement do you have that its too rich at idle?
I'm sure you know this is a huge injector and even with the shortest command pulse width it might still be very rich.
Hopefully someone with similar sized injectors and offer some guidance.
Old Dec 27, 2021 | 05:09 PM
  #72
pdxmotorhead's Avatar
Have you tried dropping fuel pressure just to see if that leans it out a bit?
You may need a manifold referenced regulator thats adjustable so at low rpm you can pull fuel.
Cause yea those are BIG
Old Apr 21, 2022 | 02:52 PM
  #73
RonSSNova's Avatar
GM 12594512 5.3 Flex fuel injectors.
These are 36 lb/hr and were in the TBSS intake I purchased.
Mostly used with the E38, but found a P59 Silverado 5.3 Flex Fuel tune using these.
Tune file attached.
The P59 is nearly identical to the P01, so the data is there. Only extra you have to do is copy the Default Pulse table to the Min Pulse table as the P59 doesn't' have Min Pulse.
Also, a handy way to find vehicle usage for GM injectors is: https://www.gmpartsstore.com/
Enter the part number and it will show which vehicles to go look up in the HPT repository.
Ron
File Type: hpt
Old Dec 10, 2022 | 10:46 PM
  #74
96caprice454's Avatar
Default Shorty deka V data 80#
I'm looking for the shorty style deka 80lb injector data. The data that's posted in the beginning, is that the older long style or the newer shorter deka V data?
Old Aug 19, 2024 | 05:30 PM
  #75
JoshuaGrooms83's Avatar
Default 1500 SEP DEKA LONG Injector data
Figure id contribute. hopefully someone can interpreted these a little better than i can.
looks like SEP is posting their injector data on their website.
I pulled their 1500 Long deka injector data and plugged them into my tune. helped with cleaning up my initial start up so i can actually start tuning my VE table.
File Type: xlsx
