Idle RPM in different gears
Old Jun 14, 2016 | 03:29 PM
redtan's Avatar
Default Idle RPM in different gears
I know that with an automatic you can set different idle RPM values for P or N or D...but I haven't been able to figure out if and how I can do that with a manual.
My E40 PCM has two values for target RPM: In Gear and Park/Neutral and then the min airflow table has gears 1-6, neutral, reverse and park.
Has anyone been able to set different RPM values for say neutral vs in gear with a manual? Or is it all one value?
