Who has used the Baker VATS bypass box?
Never heard of a Baker VATS bypass so I googled it. Wow, $35 plus shipping. You know you can bypass VATS with a 50 cent resistor from Radio Shack.
http://shbox.com/1/pass_key.html
Someone on here has to have used a Baker box. I know 1 wire from the box goes to a dark blue on the BCM, but looks like there are 2 dark blue wires from the BCM?
What is the easiest 12v wire to tap into for power to the Baker box? I assume there is a screw or something down there to use as ground.
