No cam Signal, Please help!
Old Jul 7, 2016 | 09:44 AM
vteckiller's Avatar
Default No cam Signal, Please help!
Okay i just swapped in a LQ9 (1100hp rated thompson motorsports) into my camaro. It previously had a 5.3 LM7. Both motors have 24x reluctor wheels and the only parts that changed in this swap was the shortblock and all sensors plugged right in. Same heads/cam/valve train/turbo setup etc. After the swap the car ran for a little bit but would backfire (HARD) under WOT and ran like ****. So i took it to my tuner to get the new setup tuned and thats where we discovered there is no signal coming from the cam sensor. He tried two different cam sensors, a known good PCM, checked grounds/ecu grounds. We are both stumped. Does anyone have any ideas on what i should check next?
Old Jul 8, 2016 | 09:46 AM
vteckiller's Avatar
anyone have any ideas?
Old Jul 8, 2016 | 10:18 AM
Bowtie316's Avatar
Ohm out the cam sensor wires, it's easy to snag one and break it while swapping motors.
Don't just look visually, I have seen the wire break inside the jacketing.
