lS1 maf table changes not effecting stft in the mid to upper ranges. very lean!
Old Jul 7, 2016 | 02:01 PM
milesg's Avatar
Default lS1 maf table changes not effecting stft in the mid to upper ranges. very lean!
I am Tuning a LS1 T56 swaped Trans am and cannot dial in the fuel trims for the life of me. i have gotten the idle to be somewhat stable but still get a stumble/ stall when coming to a stop. most likely from not having VSS connected but i have it on order. The biggest issue is the fuel trims up around 4000 hz is leaning out a ridiculous amount and nothing i change in the maf tables seem to change it. I have done hours of driving down my street and copy, paste special % like i would normally do and it hasent made a difference, I am able to make changes near the idle range with no problems but stft still jump around a little. I have tried to rule out VE by setting the enable rpm to 300 but it dident make a difference. I would have no problems running MAF only because it is a daily driver and wont see hard use. I have been trying to dial this in for almost a month now and have tried everything! please help! I have a short log and my tune attached feel free to lend me a hand, i will take any chance to learn that i can.
98 LS1
ported heads
Trick Flow cam 228/230 585 lift and 112 lsa
truck harness reworked by myself and 411 pcm
Truck MAF
06 GTO T56
File Type: hpt
File Type: hpl
Old Jul 7, 2016 | 07:35 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
No VSS is likely keeping your dynamic airflow in the idle zone. I'm not sure because I can look at the log file you posted, but for some reason I can't pull up the tune you posted.
