What pcm?
Old Jul 9, 2016 | 03:47 PM
Bmac89's Avatar
Default What pcm?
I just bought an LS out of a 98 Z28 to put in my 64 nova. I've heard those computers aren't the best to use due to programming limitations. Not sure if that's true or not. Is there one in particular I should look for? I'm also wanting to convert to DBW. Guessing that needs to be put into the equation.
Old Jul 13, 2016 | 09:19 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Any computer up through 1999 has quirks that you may want to avoid. If you want DBW, you will probably start at 2005. You didn't mention what your plans are, but if you run an auto you may want to get a truck pcm that is already programmed for a 4l80. If you want to go SD, C6 and up corvette computers make that more difficult. The good news is that current tuning software makes it doable with pretty much any pcm from 1998 to now.
