Speed Density Tuning with Baro sensor input
Old Jul 17, 2016 | 10:30 PM
Skydawg's Avatar
Default Speed Density Tuning with Baro sensor input
The newer MEFI ECM's have an input for a MAP and a BARO (senses ambient air pressure) sensor. Anyone have any experience with including a baro sensor in a speed density tune? Typically ECM's read baro at start up for a reference to start from the MAP (MAP = ambient before start), then MAP to calculate air density after start....would an additional baro input be that much better?"
Old Jul 18, 2016 | 11:14 AM
RedHardSupra's Avatar
Sure, when you live in the mountains, if you start your car up on the hill (lower than usual BARO), then drive down the mountains, then the ECU will still work on that lower BARO assumption, until you restart the car.
Old Jul 18, 2016 | 11:30 AM
Skydawg's Avatar
Yes, but as altitude increases, so will MAP pressure, and somewhat compensate. Question is, newer ECM's like the MEFI 6 have capacity to read BARO as well as MAP; will this greatly increase the tuning with changes in altitude?
