P0300 P0140 P0405 P0412 P0418 Ninja Please... 😒
Had my car dyno'd and the engine light was on when it came home, tuner told me too change the plugs and the misfire would go away. So i changed all 8 plugs with new wires,removed the metal boots and no change in the issues. I had the light ran at autoZone and. .... well. .... trouble. They recommended I buy a new cap and rotor..... 😂😂😭😭
P0300 random misfire
P0140 Bank 1 Sensor insufficient activity
P0405 EGR Sensor circuit low
P0412 Secondary Air system solenoid control circuit malfunction
P0418 secondary air system pump relay control circuit malfunction bank 1
X2 on my list from auto zone
I did the research on the Codes but it's like reading Arabic
, my question for you bad dudes, can I delete my egr and my AIR system to get rid of all those problems?
Could those codes be causing the random misfire?
Last time I drove my car it seemed to be down on power and the engine light was flashing, do I need a new 02 sensor on the drivers side behind the cat?
Any help is much appreciated, I don't have the cash to just go parts kamakazi and not fix the problem.
I ordered the delete plates for the AIR and EGR
also got a catch can and an air lid with k&n
