ECM wiring question
Old Aug 21, 2016 | 05:33 PM
ridedoc100's Avatar
Default ECM wiring question
I am putting 5.3 into a 1971 El Camino. I am using an ecm from a 2001 Silverado. I am using a add on fuse box assembly from BP Automotive which seems to be great so far. My question is since I plan on using the original starter wiring, do I need to supply the ecm with a crank signal.The add on fuse box has a crank signal wire in it but I think its for the starter relay which I am not using.every time I think I am done with wiring I find more do do! Thanks!
Old Aug 22, 2016 | 09:12 AM
JoeNova's Avatar
Restricted User
I think you're getting a couple of things mixed up.
By crank signal, do you mean crank position sensor? The crank sensor goes to the ECU, and should never go through a fuse panel.
The ECU doesn't need to see the power going to the starter.
Old Aug 22, 2016 | 10:31 AM
ridedoc100's Avatar
I didn't explain that to well did I ! what I meant was does the ecu need a 12v signal from my ignition switch during start and run. Thanks!
Old Aug 22, 2016 | 11:04 AM
MontecarloDrag's Avatar
You are confusing things.
If you plan to use the stock starter circuit you don't need to wire anything to the starter enable signal of the PCM. You simply hook the purple wire from the ignition switch to the starter solenoid. When you crank the engine the PCM will not know but the engine will start just fine.
If the fuse box you have has a starter relay just ignore it, it's there for the newer harnesses that have a starter relay enabled by the PCM. The 2001 PCM doesn't have this option so just wire it directly. If you have a park/neutral switch it's a good idea to use it also.
I attached the starter wiring diagram for the 2001 truck.
Old Aug 22, 2016 | 12:09 PM
ridedoc100's Avatar
Thanks for the wiring diagram! Don't know why I thought I needed a 12v crank run to the ecu. I am going to use the park/neutral switch. must be overthinking things!
