Megasquirt Tuning?
Old Aug 29, 2016 | 12:22 PM
RGNHD's Avatar
Default Megasquirt Tuning?
I apologize if this is in the wrong section. I figured it would be best in here.
I have a 2004 5.3 with LS1 Accessories. I'm running the motor with a Megasquirt MS3X system running sequential injection and spark.
Does anyone have a Ignition timing table either for a 5.3 or a LS1 for me to check my table with?
Specifically with kPa and not with g/cyl.
Thanks for any and all help!
Old Aug 29, 2016 | 12:29 PM
JoeNova's Avatar
Restricted User
Why not start with a stockish timing map and work your way up from there?
Old Aug 29, 2016 | 01:35 PM
RGNHD's Avatar
That's essentially what I'm asking for. Just a stock map to cross check all of my settings.
Old Aug 29, 2016 | 06:31 PM
RGNHD's Avatar
Originally Posted by dckmn52
Shoot me an email stude327@gmail.com and I can mail you what i have going on for reference. You can literally drag the entire table to 26 degrees fixed and the car will start and idle. VE you should be able to calculate a table based off injector size, displacement, rpm, and approximate hp and torque in the VE table maker (pretty sure thats for all MS versions)
The big thing to get them to idle is the correct idle air settings, and to have ignition timing correction for target idle rpm.
Thank you sir! I have an email sent your way. Coming from sketch3456@gmail.com(Vedem Racing).
Now for the idle. I am also not running a IACV. Is it still possible to make the engine idle decently?
