Real Time Tuning in HPTuners ?
Old Aug 31, 2016 | 07:41 PM
Fullpower's Avatar
Default Real Time Tuning in HPTuners ?
Not able to find the "Button" to enable RTT in my HPTuners program.
2Bar SD tune on 2002 Tahoe pcm.
Where should I look for the toggle ?
Old Aug 31, 2016 | 08:13 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Check the availability for your pcm. Some don't have the ability to run 2bar and RTT. Also, make sure you are running the latest version, or a really old version of HPT. When they first did the last huge update, they left out RTT entirely. Subsequent minor updates brought it back.
Old Sep 1, 2016 | 08:10 AM
truckdoug's Avatar
^ yep you gotta have 3.2 or newer.
go into the editor and select Engine>General>Real Time Tuning and then select which parameter you'd like to tune
then go into the scanner and connect to the vehicle, a little lightning bolt on a wrench icon pops up and you can access the tables there. they are numbered 1, 2, 3 etc...
Old Sep 12, 2016 | 01:32 AM
Fullpower's Avatar
still not able to find the RTT under Engine: General
Is this option supposed to be usable on a 2barSD tune ?
PCM is original equipment on 2002 tahoe.
Old Sep 12, 2016 | 01:01 PM
mightyquickz28's Avatar
FULLPOWER - So what version of HP Tuners are you using? 2.24 , its there. 3.2.55, it's there. 3.0 - nope....
Old Sep 12, 2016 | 01:11 PM
Here's where it will show up if you have it enabled...
Here (In version 3.2.55) is where you enable it and specify what you want access to ...
Old Sep 12, 2016 | 07:58 PM
dgann's Avatar
Good info
Old Sep 12, 2016 | 08:07 PM
gametech's Avatar
I completely forgot to mention that you have to write entire an RTT enhancement to your vehicle OS before using RTT.
Old Sep 13, 2016 | 06:29 PM
Fullpower's Avatar
If one does a "Write Entire" with a 2BAR OS will RTT then become possible ?
Is it possibly the case that I first did my 2 BAR OS upgrade, 6 weeks ago while running an early 3.0 version of HPTuners, and then, after the latest upgrade to a 3.2 version I have a non-enabled RTT function, hidden, and need to perform a " Write Entire " of my LATEST TUNE in order to make the RTT function activate ?
Old Sep 13, 2016 | 07:51 PM
gametech's Avatar
If available for your vehicle, 2bar RTT will be one of the enhanced options. If you used one of the first versions of 3.0, they had not re-enabled any RTT yet.
