c5 flex fuel questions
Old Sep 28, 2018 | 05:58 PM
  #121
hodge9386's Avatar
Just populated all the tables. Works fine.
Old Sep 28, 2018 | 06:32 PM
  #122
truckdoug's Avatar
could you post a copy of your tune so I can compare?
Old Sep 28, 2018 | 06:47 PM
  #123
hodge9386's Avatar
pm me your email
Old Sep 30, 2018 | 08:37 PM
  #124
rpturbo's Avatar
Hodge, your still running a MAF on this? BTW, if anyone knows how to take a config from someone else and install/use it, can you please pm me? I lost a hard drive with my configs and now I have to start over. If anyone has a nice setup they would be willing to share, I would appreciate it. Next time, my stuff will get saved on my google drive.
Old Oct 1, 2018 | 07:17 PM
  #125
hodge9386's Avatar
It was running a maf but i put it back in SD mode due to some idle issues i haven't got around to dealing with yet but yes it will run a maf just fine.
Old Nov 8, 2018 | 11:58 AM
  #126
02EBC5Z06's Avatar
Hodge,
Can you give a list of what you had to do (ie. re-pinning the pcm connectors). What did you have to do for the O2s pin wise, since you mentioned that some grounds were different, or were those secondary O2s?
I have an 02 Z06, and so does my tuner and our other friend who would like to complete this. Most of the information in the thread is helpful, but where you really started contributing to your specific scenario at post 93 is where the thread starts to shine for the C5.
Thanks in advance,
Old Nov 27, 2018 | 12:45 AM
  #127
LSxPwrDZ's Avatar
We are offering the flex conversion to the original C5 OS, so no quirky truck file issues with reverse lockout, airbags, traction control etc.
Old Dec 23, 2018 | 09:20 PM
  #128
hodge9386's Avatar
I actually do have a reverse lockout issue with mine but everything else works fine. I just push through the lockout and it's not that big of a deal for me.
Old Jan 28, 2019 | 11:00 PM
  #129
maxgee's Avatar
I had an 04 Tahoe file and did something in the tune (can't remember now) and did not have the reverse lockout issue, but I did feel as if the pedal was quirky under light throttle and got tired of the fuel reading issue I was having.
I am wondering if your pedal has the on off feel when you first press it and release it? If not, I will try the OS you are using and do a compare to see why I managed to resolve the reverse lock out in the tune.
Old Feb 5, 2019 | 12:52 AM
  #130
LSxPwrDZ's Avatar
One of the many problems using segment swapped tunes in a C5. All the background ETC and Pedal info you don't have access to gets swapped with the segment so you have pedal/throttle tables for a flex truck or SUV now.
Old Aug 6, 2019 | 11:04 PM
  #131
AINT SKEERED's Avatar
in a 2000 trans am, can I load a 03 express van flex file in ? I have a manual valve body 4l80 . I will also have to make my vin match again as well , we have to plug in for state inspection in Baton Rouge parish. I have a sensor and pig tail to install, just have to get operating system correct. thanks
Old Aug 24, 2019 | 07:36 PM
  #132
rpturbo's Avatar
You can't just load a express file on a 2000 ecm. They are totally different ecms. You can use a express van ecm. All the info is in this thread.
Old Nov 3, 2024 | 09:55 AM
  #133
NemeSS's Avatar
Old Nov 3, 2024 | 09:58 AM
  #134
Originally Posted by NemeSS
Meanwhile.... SIX years later......
Old Nov 5, 2024 | 02:33 PM
  #135
NSFW's Avatar
It's kind of funny seeing people tell a C5 owner to use an "express van" PCM for this, because the 2004 C5 used that same PCM. And since the 2004 used the same PCM, there's clearly no issues with DBW (there were some questions about that earlier in the thread).
It's my understanding that an alternator wire should be moved from pin 52 to 75 on the connector that was red with the P01 and becomes green with the P59. That's what I did when I upgraded my 02 C5 to a P59, and it works fine. Given all the comments early in this thread about not needing to move any pins, maybe that wasn't strictly necessary.
The P59 also expects to be monitoring current from the O2 sensor heater grounds, so you'll get some check engine lights from not having those wired up, but they can be disabled and you'll still be exactly as good as the 2002 cars were when they left the factory.
