Swap Ecu pins
Old Nov 3, 2024 | 08:02 AM
Dweeks2's Avatar
Default Swap Ecu pins
First post here, I have a 1977 k10 and I’m swapping a 6.0 lq4 into it. I’m running the th350 trans so I have deleted all of the transmission sensors from my harness. I should also mention this engine is drive by wire. I will be using the factory speedometer and no cruise control so my question is I have 3 pins left cut and unconnected I believe I won’t need but I’d like confirmation.
On the GREEN connector I have:
pin 10 Engine Speed Signal
pin 50 Vehicle Speed Signal
on the BLUE connector I have:
pin 33 TCC Brake Switch/Cruise Control Release switch signal
Old Nov 5, 2024 | 09:02 PM
the_merv's Avatar
PCM like to have a speed input to run some stuff correctly so you might have an issue. Won't need the TCC stuff just turn off the codes and the tune set to a manual.
