stumped, 4l80e TCC lock up issue
Old Sep 29, 2016 | 10:48 PM
truckdoug's Avatar
ok i just notice in the trans diagnostics it will max line pressure if it sees a maf fail, so I have disabled those...now i'm just scratching in the dirt really...will try again tomorrow
Old Sep 30, 2016 | 09:43 PM
truckdoug's Avatar
no joy. back where i started. i can command a lock up but no lock up otherwise.
i guess my next step is flash the tune from the other, non-turbo, 5.3/4l80e truck and see if it'll lock that converter.
or I could just wire a switch to throw pin S to ground and be done with it! but nooo i gotta try and make it all work correctly
Old Sep 30, 2016 | 09:57 PM
2xLS1's Avatar
Are you logging TCC mode? What does the scanner show for TCC Mode when the parameters are being met where lockup should occur?
Old Oct 1, 2016 | 11:40 AM
truckdoug's Avatar
I am not, and that is one of the reasons I'm having a hard time figuring it out.
I can add TCC Mode as a channel, but I can't seem to find it in gauges. Is there another place I can log it?
or can I just view it in the channels "value" ?
Last edited by truckdoug; Oct 1, 2016 at 11:44 AM. Reason: oops I think i figured it out
Old Oct 1, 2016 | 01:49 PM
2xLS1's Avatar
I can't help with that. I'm still using 2.24
Old Oct 1, 2016 | 01:52 PM
truckdoug's Avatar
gotcha. yeah i was just getting used to 2.24 when they switched. still learning.
heck i'm just a baby to this whole computer tuning thing, but dang its it great when you figure it out!
it's wet out today, will report back when I can take it for a drive.
Thank you for your help. I really appreciate it.
Old Oct 10, 2016 | 08:55 PM
truckdoug's Avatar
finally a dry day to take the turbo truck out.
i was logging the TCC mode and it never changed from "off"
could there be a DTC I accidentally disabled to cause that?
Old Oct 11, 2016 | 08:18 PM
truckdoug's Avatar
rigged up a switch to ground trans pin S, works great. not sure what I goofed up in the tune to cause this, but it's not a daily driver so no biggie.
if I ever figure it out i'll dig this thread up and post for posterity, lol
Old Oct 12, 2016 | 12:12 AM
joecar's Avatar
A long shot: set the 4th TCC Apply curve a few mph higher than the 3rd TCC Apply curve.
Another long shot: set TCC Release vs Speed to 100% in all cells.
Old Oct 12, 2016 | 12:15 AM
joecar's Avatar
There is a pid which shows the reason why TCC is unlocked.
Old Oct 12, 2016 | 06:16 AM
truckdoug's Avatar
Thanks Joe, I'll give those a try.
Old Oct 19, 2016 | 01:32 PM
  #32
watman02's Avatar
Post your tune.
Old Oct 19, 2016 | 07:42 PM
  #33
truckdoug's Avatar
the earlier version of my tune is in post #3
i have since switched to a more common OS, and i'll post that up as soon as I get home from night school.
Old Oct 19, 2016 | 10:35 PM
  #34
truckdoug's Avatar
ok here tis.
i might have a log around too if you think it'd be useful.
File Type: hpt
Old Oct 20, 2016 | 07:59 PM
  #35
Russ K's Avatar
Set your TCC Release TPS speed table back to stock.
Russ Kemp
Old Oct 21, 2016 | 08:32 AM
  #36
truckdoug's Avatar
will do. supposed to be dry saturday so hopefully I can give it a test.
also need to test out the drag radials
Old Oct 22, 2016 | 04:52 PM
  #37
truckdoug's Avatar
well the drag radials are fun, but they didn't help the TCC lock
not real sure what my next step is.
my logic is
if I can command it locked my wiring ought to be good and i can eliminate that as the issue.
so cross wiring issues off.
cross mechanical issues off
that leaves me thinking it's the tune (or possibly the PCM itself)
so to eliminate the possibility it's the PCM i will flash it with my daily driver's tune (same base OS, 5.3/4l80e) and see if it locks the TCC
at that point it's got to be an issue with the tune or trans segment.
Old Apr 23, 2017 | 07:02 AM
  #38
zapp109's Avatar
Bumping this Im having same issue. Checking if anyone had this issue and solved the problem. Only thing maybe different is mine locked up briefly by itself without command on a handful of occasions.
Old Apr 23, 2017 | 08:17 AM
  #39
truckdoug's Avatar
can you command a lock up?
Old Apr 23, 2017 | 06:44 PM
  #40
zapp109's Avatar
Yes lockup can be commanded.
