What map value denote
Old Jun 21, 2004 | 10:39 AM
HumpinSS's Avatar
Default What map value denote
the beginning of WOT
Old Jun 21, 2004 | 11:38 AM
jimmyblue's Avatar
Moderator
WOT threshold shows as 94% TPS, this is a value box
you can change in HPTuners.
PE threshold on my car is set to MAP=15kPa stock.
That's a pretty low threshold to start enriching(?).
It does not discriminate WOT per se. There are PE
modifiers for other things, that I haven't gotten to
understanding yet.
I would like to build a model that combines all of the
"enrichment actors" and lets you see the true
enrichment response (between open loop A/F, the
various PE tables / modifiers, etc.) across the RPM,
MAP, TPS, MAF inputs. It seems conceptually messy
to me right now. Like PE vs RPM, without comprehending
MAP, seems like a pretty misguided enrichment basis
what with MAP or CylAir being the key burn rate
factor.
Old Jun 21, 2004 | 04:46 PM
Bink's Avatar
Hey!!!!
WOT, as jimmy says, anytime above 15kpa. Look at the WOT/Cold table - defined as TPS percent and RPM.
Here's an interesting thread with some good info on WOT http://www.efilive.com/forum/viewtop...er=asc&start=0 FWIW. How's the Monster cam??
joel
Old Jun 21, 2004 | 06:57 PM
HumpinSS's Avatar
The monster cam is killing my *** trying to tune but i will prevail and work this out. I broke donw and bought HPTuners because of lost PCMs so I wont be tuning till i get it
Old Jun 21, 2004 | 07:47 PM
Bink's Avatar
Stay at it. It took me 8 months ( Eight!!) to tune mine. Cam was in by May 2003 , started the new VE table between Christmas and New Years '04. Thank God for NoGo ( He is The MAN!).
I'm sure you will progress quickly with HP Tuners . Keep me posted.
joel
Old Jun 21, 2004 | 07:56 PM
HumpinSS's Avatar
I was trying to wait for Efilive Flash scan but couldnt hold out. I guess i will have a damn good compro since i haves tested tow of the three so far
