Swapped to a smaller cam - one question
It thumps like the bigger cam, but it's running rich. I can smell it. And reading the narrowbands they are pegged at 900mV. I leaned out the big cam to get the narrowband down as close to 0 as I could. Is that the same strategy with the smaller cam or try to get it around stoich and switching? I'm hoping it idles at stoich much better than the bigger cam making CL possibly without dips or slight hiccups. But I just was wondering what I should be aiming for? Smaller cam seems to be much less fickle...
One other thing; it is reading 80kPa at 800rpm (rich with low timing) vs the 68kPa in the bigger cam at 950 with a lot of spark and very lean. I'll set to 950 and it should be around 50-55kPa there... So not concerned as I'm using pretty much stock values for air and spark. But it thumps harder because of that kPa reading which I thought was interesting.
Honestly, your bigger cam might be a closer starting point. I think the 900mV readings are telling you the strategy for the new cam will
Mirror the older cam.
I would think it would idle around 55 to 60 kpa when you get it dialed in. It might still like 25 degrees idle timing.
I need to get the air bubbles out of the coolant first. Still had a bit yesterday which limited how much time I could spend on it since the temp creeped up to 220. Hopefully today I can go out and work on the idle and **** off the HoA.
