Throttle response / Tip-in
1. Is there anything in HP tuners that helps with throttle response ?(eliminating delay of foot pedal) (2015 Camaro SS) There are several products out there that help - "Vitesse" "Pedal Commander" etc. But is there any adjustment in this software that would solve that problem to prevent buying another product.
2. I hear the term "Tip-in" a lot. Who can give a shirt sleeve explanation of what this is? What is it and where does it show up in the performance of the engine and how can it be adjusted?
Thanks,
" Desired Throttle Area - A: Normal Mode Desired throttle area based on pedal position and RPM or VSS (pedal to throttle map). WARNING!!! Modify this table at OWN RISK. Incompatibility of this calibration with the vehicle TAC module calibration may render PCM permanently inoperable."
