LTFTs
Old Oct 8, 2016 | 11:07 AM
camarovon's Avatar
Default LTFTs
01 camaro ,what can cause my fuel trims to go postive 11.7, and stft -3.2
Old Oct 8, 2016 | 10:46 PM
Boosted53F's Avatar
how many counts of data do you have for these numbers? what are you using to find LTFT and STFT? just a basic obd2 scanner?
could be a number of things, but maybe check for vacuum leaks first.
is car stock? cam? bolt ons?
Old Oct 8, 2016 | 10:52 PM
camarovon's Avatar
Its a 408. 244/248 cam ,fast 102,102, I'm using hp tuners,could my tune be that far off?
Old Oct 8, 2016 | 11:01 PM
Boosted53F's Avatar
without knowing much about the history of the car i would say yes.... it can be that far off. Has the car been tuned yet? Are you datalogging with a wideband for reference?
Old Oct 9, 2016 | 11:34 AM
Darth_V8r's Avatar
Moderator
The job of the LTFT is to work the STFT to basically zero. The best thing you could do would to tune your VE and maf to where you don't need LTFT
Old Oct 9, 2016 | 11:21 PM
camarovon's Avatar
Default ltft
could u explain on how to do it
Old Oct 10, 2016 | 10:56 AM
Darth_V8r's Avatar
Moderator
Shot you a text
Old Oct 10, 2016 | 12:08 PM
Exidous's Avatar
That's a pretty big task in a simple forum post but you can check this out as a start.
Download this and keep it forever!
There have been some changes in the scanner since the pdf was made but all the steps are still very relevant.
Note that MAF tuning is VERY sensitive. Make VERY small adjustments.
