RAF Config doesn't agree when I drive around?
Moderator
Received 1,836 Likes
That's awesome! It's a lot easier when the airflow calls all match up. Then when you command a certain amount of air, you get what you're commanding. Makes a big difference
Yup. Still a slight little surge. But I need to play with the cracker table. Going back to stock and work from there. Will tell me if I went the wrong way or not.
I had the car idling without adaptive idle at 800. So, that also helps. Tomorrow when it cools off I may re-run RAFIG and see what it says.
I'll also probably try to take the idle down to 650 so I can hit the 400 column and see if I need to lean it out or add fuel. Then I'll switch over to the MAF. And that should really solidify the idle.
Enabled MAF today. Just used my old tune file. Idle as about 15% lean... richened it up. Everything else was within 3-5% so it was one run around the block for about 25 mins. MAF is tuned now except for WOT blasts. That'll be later when I can get to the 1/8 mile track.
It's amazing how perfect the car drives on MAF. And I'm using a 100mm MAF. No surging. No bouncing as I come to a stop. It just holds the a/f much more stable.
