flex fuel OS for 0411 P01 pcm
Hi guys I've hitting a brick wall with HPT customer support. I can't see to get ahold of the usual guy I speak with.
I'm looking for an OS that will:
A) work with a P01 '0411 PCM
B) have 4l80e segment available
C) flex fuel enabled
D) drive by cable TB (IAC stepper)
E) 3 bar upgradeable
Thanks!
Thanks!
you need to buy an 04+ express van pcm i.e. p59, then flash the express van file that has a 3 bar upgrade available OS along with flex fuel tables.
The pcm also needs to have a "chip" required to run your IAC motor.
add the wiring for tps, iac motor. And if you want to keep some o2, then add a ground.
more details on this link, take down if not permitted.
http://lt1swap.com/cable_conversion.htm
good luck.
good luck.
I believe subeone is correct, you may need to move to a P59 PCM. I have a P01 PCM with flex fuel, but there is no 3bar OS for it (only 2 bar). The only P01 flex fuel PCM's I've found also didn't have a 3 bar OS available. Each P59 I found with flex did have a 3 bar OS available.
