Help me chose a tuner.
I am ready to buy a tuning device for the car. I'm leaning toward HP tuners but I HATE the fact that they have no phone number so I can ask preliminary questions or call them if I get into a jam and potentially cause a problem. I looked at EFI live and do not like the fact that it's in NZ. I tried calling Diablo about the Trinity but I fell asleep while the phone just rang and no one answered.
I have owned a Fast XFI system before and I have been using SCT with Mustang for years so I have an understanding of how those products work but not HP tuners.
I have a lot of questions about the HP tuners so if anyone here wants to help I can fire them off.
2. When I plug the HP tuners in will I have direct access to the current tune that's in the car? Will I be able to make changes to that tune and use that as my base and work with it?
3. I understand the HP PRO has the Datalogging capabilities with it and some extra channels to log AFR and such. Does the user actually have the ability to make changes to the AFR, Timing tables, and things like that? Can the timing only be done globally or is it an actual table to work with?
4. Last thing is with the SCT ive been using it was a basic handheld that you can change timing globally and then some other basic things and any real tuning you wanted to do needed to go to a tuner. I'm trying to establish if this is like SCT in that aspect or is this more user interface?
2. Yes, you have direct access. You can also store infinite versions of your current tune with changes for octane, etc and just reflash when needed.
3. Actual tables. No half-assed SCT or DSP type stuff. You get full access to every single table in the ECU. Its overwhelming your first time.
4. HPTuners is basically a full control interface. You can control pretty much every single parameter in the factory ECU. With the standard HPT not being much more than an SCT, I'm baffled by the idea that anyone would spend money on the SCT with it having very very limited access to the stock ECU.
1. Does the HP Pro kit come with a Handheld that stays in the car and stores the tunes in it? I want to know if I could store multiple tunes like a street tune, an aggressive track tune and then maybe one for NOS
no, tunes are loaded from your laptop directly to the PCM via an ALDL cable.
yes, you can read that tune and work on both with the editor and the scanner (using the real time tuning function)
yup timing tables are editable with HPT as with most tuning software.
this is more in depth. you can change pretty much any of the parameters that GM put in, plus a couple more.
I have used HPTuners most vs efi live & tuner studio (micro/megasquirt) . They all vary a little bit but they essentially all do the same job.
All the software makers really do is maintain the software. It's up to you to know how the PCM controls engine function.
My wife's been driving the car and she smells like a Carburetor lol.
