Issues Cruising stalled ls1/4l80e
Setup-
-94 S10, 8.8 rear. Caltracs, DRs.
-LS1 Intake, ls6 intake mani, LT headers, no cats mated to a 4l80e
-Circle D 4,200 stall
-PCM of NC 4l60 to 4l80 Conversion Harness http://www.pcmofnc.com/product/pcm-o...rsion-harness/
-Base transmission tune from PCM of NC and I maxed out misfire tables myself(researched the issue and this was the fix)
-added a 4l60e harness
Located in Central NJ, so if anyone local can help that would be cool!
It also unlocks at 56% throttle again. You could extend this row on to keep it locked in 4th on the street. Don't know if this will work, but give it a try. Be sure and save your original tune first.
I noticed when playing back my log that theTPS had no reading what so ever. Will have to take a look at that tomorrow.
If that doesn't work you have a trans or wiring problem.
If it does work, then the tune needs to be examined more carefully.
Is this a brand new build? Did it ever work correctly?
When you say "acts like it is in neutral" does that mean if you give a little gas the engine revs and the car does not accelerate at all? If true that has nothing to do with TCC tuning. It appears the trans does not engage 4th gear.
If this turns out to be a trans problem, I will move this thread to the Automatic Transmission section.
I got the transmission off Craigslist for cheap but it seems okay. I went from a t56 to this trans so this is the first time im using it.
The issue is the engine revs up but the truck doesnt accelerate. I can get it to accelerate again by mashing the fun pedal... Then at that point im way past the speed limit.
This truck wasn't built to be a daily but I want it to still drove normal through town. Hopefully that's still possible with the stall.
You probably want something more in the 2800 stall range.
