DTC Code P0121 Low Voltage TPS
Old Nov 7, 2016 | 04:06 PM
tnmotown's Avatar
Default DTC Code P0121 Low Voltage TPS
When this happens, does the sensor need to be replaced? I have noticed when it does come on the car tends to shift funny at WOT. If I clear the code then it will be fine.
I also recently installed a NOS WOT/RPM window switch and it has a wire to splice into my TPS. So I tapped into the 24 dark blue wire on the red side PCM and when I did that, it will only read around 2.8 Volts max when I stomp on the pedal.
I removed the sensor and it kinda looks fairly new, not dirty or anything. Could it be in the tune? A new sensor to be safe? Any help would be appreciated. Thanks!
Old Nov 9, 2016 | 01:13 AM
tnmotown's Avatar
Well I'm going to have my tuner check it out tomorrow, I'll report back
Old Nov 9, 2016 | 04:19 PM
Russ K's Avatar
Do you have a performance camshaft? If so, there are a couple tables for the P0121 in the tune that need to be changed for the lower vacuum of a performnace cam.
Russ Kemp
Old Nov 9, 2016 | 08:05 PM
JakeFusion's Avatar
Super Hulk Smash
2.8V? Was it doing that before you spliced into the TPS wire? That wire is extremely sensitive to voltage irregularities.
Old Nov 10, 2016 | 09:20 AM
mrvedit's Avatar
Moderator
Exactly what I was thinking.
A high impedance circuit (like a volt meter) can read the TPS value, but anything that drains more than a few hundred MICRO-amps of current from it will reduce the voltage.
Disconnect the splice and check the voltage - if it still doesn't range from about 0.5V to 5V, then you likely have a sensor problem.
