LS3 Mass sensor on a LS1 (AIT delete)
Old Nov 9, 2016 | 10:06 PM
Ogoz23's Avatar
Default LS3 Mass sensor on a LS1 (AIT delete)
Hey guys I will be using an ls3 mass sensor on my ls1 swap , now I know that you have to program the pcm to read the ls3 sensor. But my question is , I know that the ls3 sensor has an incorporated IAT sensor , and I believe my 05 5.3 has a separate sensor for the IAT .. what do I do with this , do I delete the stock IAT sensor and utilize the one from the LS3 Mass Sensor. And what do I tell the harness builder, to wire the the mass sensor and IAT sensor as it was an LS3 ?
Old Nov 9, 2016 | 10:28 PM
lilaaron233333's Avatar
If I remember right I think I was told the closer to the TB the better(AIT sensor). That way it's more "accurate" to what the temp of the air is going into the motor. Idk for sure tho I'm sure some one will know more then me lol and have more input. .
Old Nov 10, 2016 | 08:49 AM
JakeFusion's Avatar
Super Hulk Smash
For the stock LS1 wiring harness, I just got the conversion adapters from Casper that connect into the two plugs on the harness and then one connector plugs into the LS3 MAF. If you're getting a harness built, just tell the builder to use the 5-pin LS3 type vs the separate MAF/IAT.
As for the tune, you'll need to modify the IAT scale. My stock table was:
Code:
Labels	0.00	6.25	12.50	18.75	25.00	31.25	37.50	43.75	50.00	56.25	62.50	68.75	75.00	81.25	87.50	93.75	100.00
Inlet Air Temp	283.8	215.6	172.4	149.0	129.2	114.8	102.2	91.4	80.6	71.6	62.6	51.8	39.2	26.6	10.4	-13.0	-40.0
Modified to this:
Code:
Inlet Air Temp	270.8	202.6	159.4	136.0	116.2	101.8	89.2	78.4	67.6	58.6	49.6	38.8	26.2	13.6	-2.6	-26.0	-40.0
Old Nov 10, 2016 | 08:52 AM
Ogoz23's Avatar
Thanks Jake! Do I also need to modify the Mass sensor scale ? I've heard they read different frequencies.
Old Nov 10, 2016 | 08:57 AM
JakeFusion's Avatar
Super Hulk Smash
Yes. If you do it in a 100mm-ish tube this is the baseline transfer table. You'd need to tune against this. I've started here with my LS3/100mm MAF combo, and added 15% above idle regions and kept close to this for idle regions in cammed cars. For a 5.3L with less cam, I might just leave as is and do some driving to see how far off it is in the light load areas. If it's off 5-6%, just extend it out the rest of the frequency range that much.
But try to maintain this shape of the slope. Don't add 8% somewhere and subtract 5% in the next cell. Try to keep the shape and just move the whole thing up or down as needed.
One thing to note: the MAF frequency is narrower with the LS3 vs the LS1 MAF.
Code:
Labels	1,500	1,625	1,750	1,875	2,000	2,125	2,250	2,375	2,500	2,625	2,750	2,875	3,000	3,125	3,250	3,375	3,500	3,625	3,750	3,875	4,000	4,125	4,250	4,375	4,500	4,625	4,750	4,875	5,000	5,125	5,250	5,375	5,500	5,625	5,750	5,875	6,000	6,125	6,250	6,375	6,500	6,625	6,750	6,875	7,000	7,125	7,250	7,375	7,500	7,625	7,750	7,875	8,000	8,125	8,250	8,375	8,500	8,625	8,750	8,875	9,000	9,125	9,250	9,375	9,500	9,625	9,750	9,875	10,000	10,125	10,250	10,375	10,500	10,625	10,750	10,875	11,000	11,125	11,250	11,375	11,500	11,625	11,750	11,875	12,000
Airflow	3.180	3.578	4.039	4.570	5.180	5.859	6.633	7.492	8.438	9.500	10.648	11.922	13.313	14.813	16.438	18.211	20.102	22.141	24.328	26.656	29.148	31.813	34.633	37.617	40.789	44.141	47.680	51.406	55.328	59.461	63.797	68.352	73.117	78.109	83.328	88.781	94.469	100.406	106.594	113.023	119.719	126.680	133.906	141.406	149.188	157.250	165.609	174.258	183.211	192.461	202.031	211.906	222.102	232.633	243.477	254.680	266.211	278.078	290.313	302.898	315.844	329.148	342.844	356.898	371.344	386.172	401.391	417.000	433.023	449.453	466.289	483.547	501.227	511.992	511.992	511.992	511.992	511.992	511.992	511.992	511.992	511.992	511.992	511.992	511.992
Old Nov 10, 2016 | 08:59 AM
Ogoz23's Avatar
Copy , I am using a 102mm tb and tubing and a 228r cam. If that tells you anything
Old Nov 10, 2016 | 09:04 AM
JakeFusion's Avatar
Super Hulk Smash
I'd start there and above 3000Hz add 10% across it. Don't do any WOT runs of course, but that should get you close to start with.
Old Nov 10, 2016 | 09:15 AM
Ogoz23's Avatar
Thank you!
Old Nov 10, 2016 | 05:50 PM
Ogoz23's Avatar
Jake , can the tuner just copy the Mass and IAT peramaters from and LS3 and just put them on an ls1 tune as a starting point when upgrading to an ls3 Mass?
Old Nov 10, 2016 | 06:54 PM
JakeFusion's Avatar
Super Hulk Smash
The columns are different... So it's not a 1:1 paste.
