Good to start?
Old Nov 13, 2016 | 06:23 PM
93Rat's Avatar
Default Good to start?
So I finally got my motor together after a h/c swap. Cam is a tsp tsunami, prc 225 heads, ls6 intake, all new lifters/p rods. I want to try and start it and check for oil pressure/make sure everything sounds good. My question is, does it matter that I have not had the pcm flashed for the cam? It would be on a factory tune with factory injectors. It should run, just rough without a tune right? Thanks in advance
Old Nov 13, 2016 | 06:50 PM
TheZ346's Avatar
It may die a couple times but it will idle.
Old Nov 13, 2016 | 08:17 PM
93Rat's Avatar
Thats what I thought. I'll post up my results in the coming weeks.
