First start running rich
https://lh3.googleusercontent.com/T8...=w1503-h844-no
What ecm tuner are you using.
WHen I put cam heads turbo larger tb on my motor you would think I would of needed more fuel right? Not even close I had to subtract about 20% in my ecm idle to get it to just start.
The values in the "VE" (Volumetric Efficiency) table roughly indicate how close to theoretical efficiency (in %) the engine is at that RPM and Throttle opening. The overlap of a large cam wastes air/fuel at low RPM and the efficiency is therefore very low. However at high RPM the cam allows resonances in the intake and exhaust system to boost efficiency past 100%. (Some people call this the "ram effect", but engineers say that isn't really accurate.) This is all greatly simplified, but hopefully helps conceptualize the meaning of the values in the VE table.
To me this indicates a likely misfire or dead cylinder, either of which allows a lot of unburned oxygen to hit the O2 sensor and show super lean. (Notice I did not say unburned fuel because O2 sensors measure "unburned" oxygen.)
An infrared thermometer is very useful here if you have headers. Read each header pipe right at the cylinder head and you will likely figure out which has the misfire. I once had a dead injector and that cylinder read 90F at idle.
A bad injector, bad plug or bad coil is the likely culprit.
Harbor Freight and other discounter often sell infrared thermometers for under $30 and they are very useful for automotive diagnostic work, And also in the kitchen; meaning your wife will approve it and then steal it.
More than just a camshaft will come into play when tuning your motor. Dont get me wrong mail order tunes are good for slight upgrades but you need to bring it to someone local with a wideband.
There are some guys that make you / send you their data log , scan tools then ship them back and do a tune thats acceptable but some guy just guessing will never be spot on.
HP tuners is like 400$ after a few tunes it pays for its self. Best tool you could ever buy.
