Supercharged L92 missfire help
Anything that changes the mass and harmonics of the crankshaft will affect this calculation and can cause misfire codes. This includes a different torque converter and certainly the additional load of a supercharger.
I don't know if a "Crank relearn" might cure your problem, or if you will need to disable the code (as do many people with high stall converters.)
Hopefully one of the pros here will chime in and give you a definitive answer.
