4.8 ecu on a 5.3
4.8 ecu on a 5.3
i have a 4.8 running in my car. but recently i bought a used 5.3 engine. i was trying to bench run it to check the oil pressure and see if it run ok. i put the 4.8 ecu on and the engine flood at first. then when i got the engine running it had high idle and it surging , it also has hard starts.
Agree with subeone. If its a factory swap, 4.8 to 5.3 it will run. Have had tons of customers swap out 4.8's and 5.3's for 6.0 and drive them to us for a tune. Now if you changed camshafts, injectors, maf's, intakes etc. it could be a tuning issue.
