E38 Vats
Old Mar 11, 2017 | 11:45 PM
Revoroller's Avatar
Default E38 Vats
When the vats is armed on with a E38, does it not allow the starter to engage?
2008 gmc sierra (vortec max) owner swapped the L76 for a LY6, I was going to disable the DOD - Truck starter before hand, licensed the ECM, disabled the rear 02s and DOD - flashed the tune and no start, wont even attempt to crank. No fuel psi. So I figured the VATs enabled - I've disabled both VATs patches and starter fault check. No change, will not crank or power the fuel pump. Am I missing something with the VATs disable? Yes, I did "Write Entire"
Old Mar 12, 2017 | 11:05 AM
2xLS1's Avatar
If you are sure you wrote back a file based on what was read out of the truck then disconnect the battery for a few minutes. I had one do that to me once and that got it going again. I think it was a 08 also.
Old Mar 12, 2017 | 11:25 AM
Revoroller's Avatar
We actually tried this as well. Reflashed it to the stock tune file that I had pulled and it did not change anything.
Old Mar 12, 2017 | 11:32 AM
LSX Power Tuning's Avatar
It will spin over VATS kills the injectors.
Old Mar 12, 2017 | 11:44 AM
Revoroller's Avatar
I knew this was the case with gen 3/411ecm, wasn't sure if there was a difference on gen 4 with a e38 ecm.
I have verified power to the relays for fuel and starter. Could this be an issue with the BCM?
Old Mar 12, 2017 | 06:41 PM
Revoroller's Avatar
Good news, but odd. Came in this morning to troubleshoot some more and the truck fired right up first try.
