Flex Fuel Fourth-Gen
So we are converting my 02 Camaro over to flex fuel. So far we have the flex fuel sensor wired into pin 56 on the blue connector and are using a flex fuel OS from a 2002 Tahoe (OS 12216125) in which we changed the displacement from 5.3 to 5.7. We have upgraded the pumps and swapped out the fuel injectors to 1000cc FICs in preparation for boost. However, we are trying to get it running straight NA first. We know that the system is seeing ethanol content as we have been logging it already. We are using EFI Live for the tuning duties.
However, we are running to a few problems. First of all, the injector data that we input to EFI Live for the FICs keeps changing 2-3% after we save the file and reopen it. See the pictures below. This is after we put a base tune in it. The car starts but still isn't running right and there are other problems (see below)
Data just after inpute
Data after save and reopen
Data after input
The second is that the BCM doesn't seem to be in communication with the ECM any longer. The 6-speed manual won't let us shift it into reverse after uploading the new OS and we have a constant "Service Vehicle" light on that wasn't there before. We updated the VIN on the new OS to match the car, but no luck.
Sorry for the long message, but I was hoping someone could point me in the right direction.
Thanks in advance!
My guess on the reverse lockout is that the OS doesn't know it's a manual transmission. You can either try to fake the OS so that it's a manual (will require making some hex changes), or disconnect that lockout solenoid. The car will not longer be able to protect against shifting into reverse, but you will at least have reverse.
As for the service vehicle light, I am not as familiar with that one. I would have to do some looking to see if it's just the BCM that is unhappy, or if there was something else going on. Do the gauges in the dashboard still work?
I'll have to look into the '04 Corvette OS too to see if I can get something like that to work. I'll test these out and let you guys know. Hopefully I can get it to work and we'd have an easy solution for getting fourth-gens going flex fuel.
As for the '04, yes there are several Flexfuel OS's in the 1 MB PCM's. If you not stuck on a 512 kB, then going to a 1 MB would be an easier swap IMO.
