Throttle weirdness
Old Apr 25, 2017 | 07:17 AM
Dave MacDonald's Avatar
Default Throttle weirdness
Trying to help out a buddy with his '06 ZO6. All stock. (warning, this could get long.)
He bought the car last summer, and complained of slow return to idle. RPM would flare to 15-1800 after pushing in the clutch at slow crawl. Inconsistent depending on how much load was on the engine at the time. The rpm would always settle back down to normal idle within 10 seconds or so. Annoying, but not a real problem.
Fast forward, I had to put a water pump on it in January due to a leak, The throttle body was removed for easier access, and cleaned with cloth damp with cleaner, not sprayed down, just wiped.
When it was put back together the idle would hang higher, 18-2200, and either really slowly come down or stay there. You could load the engine down with the clutch and bring the RPM down to idle, where it would stay until you gave it some pedal and it would flare up again. It's more than annoying at this point.
Diagnostics for vacuum leaks found none. PCV hose replaced for the hell of it, intake gasket is like new. It went to the dealer for a throttle relearn and it was worse.
I borrowed a 87mm Trailblazer SS throttle body just to try and the car runs mint. Better than it ever did. No more hanging RPM's , no flaring, nothing. Run's perfect. No throttle relearn procedure other than let it idle up to temp.
Ok, so we decide that old stock throttle is at fault and buy a new Delco replacement.
Throw the new one on and... same issue. hanging RPM, flaring, drive-ability issues. Oh, and no DTC's through any of this. Crap!!!
Put the Trailblazer throttle on, mint, no issues.
Take the car back to the dealer with the 87mm on to show them how it is running perfect. Get them to change to the new 90mm and do the relearn procedure and before the tech gets it out of the bay its acting up. "Hmm, that's weird".
Now it's even worse, Try driving this thing when it won't go under 2500 rpm. No p0507 code, data log not showing anything odd going on with the pedal , yet it is like it is being told to open the throttle. Throttle position log shows the movement.
He got a smoking deal on a brand new 87mm throttle body, so he bought it and the car runs mint with it too.
So 2 stock 90mm throttle body make it act up, and it runs perfect with 2 different 87 truck throttles.
So, shy of the new 90mm being faulty out of the box, with the same issue as the original one, does anyone know, or can think of any reason to explain this?
What, if any, hardware or electronic differences are there between the 90 and 87.
He is perfectly happy driving it around with the 87, other than his engine covers wont fit, but it drives me nuts not knowing what is causing this. Dealer seems uninterested in digging deeper.
thanks for reading.
any insight is appreciated.
Old Apr 25, 2017 | 09:50 PM
2xLS1's Avatar
Try doing a throttle clean reset with a scan tool. HP Tuners scanner will do it.
Old Apr 26, 2017 | 09:15 PM
Lsxford's Avatar
I agree, sounds like theyre not doing the relearn procedure correctly. I have seen this 100s of times, cleaning the sludge from the throttle body, even a small amount of build up, changes the idle airflow the pcm has learned.
