Gen III 2003 Truck PCM
Hi,
I was wondering if the Gen III 2003 Truck PCM has PWM signal that can be used to run a variable speed radiator fan?
I was under the impression that the PCM have only high and low fan outputs, but my tuner said that the PCM have that ability. Can somone verify that?
I have a 2008 Volvo XC70 radiator fan that Im planning to install. It delivers a ton of air and this requiers a PWM signal..
Thanks!
Morten
Thanks!
Morten
IIRC the Trailblazer EXT with the 5.3's used a Blue / Green PCM and had an electric fan clutch that was PWM, I'm not sure if the signal would be correct or be able to supply enough current but you might be able to make a small circuit to modify the output, if need be.
