HP and boost controller questions.
Old May 6, 2017 | 11:52 AM
323z's Avatar
Default HP and boost controller questions.
I know holley has a tech # but I don't feel like holding for an hour plus. So I figured maybe someone here can help me with my question.
So I have a holley HP and all the inputs are being used.
So my question is can I double the spring pressures without running dome pressure and the sensor?.
At the moment just running turbo compressor housing to bottom ports on WG w/6lbs springs i.e spring pressure.
if I run the top ports of WG's to Holley/Mac boost cylinder/controller.Then controller through the Holley ecu to achieve more pounds then what the springs are. Can I do that without having to use Dome pressure?
Thanks
Old May 11, 2017 | 10:03 AM
rpturbo's Avatar
That title is going to be mis leading, most guys are going to see that and think HP Tuners. If you can change it to Holley HP, youll probably do better.
Old May 22, 2017 | 12:43 PM
323z's Avatar
Thanks rpturbo. Yeah I was kind of thinking the same thing on the Title.
But I have found my answer, Yes!. Running the loop function instead of dome pressure will get you double the spring #'s. I had my 6# springs up to 12#'s. Was at 80+% duty on the 6# springs on 12 #'s. It did what I wanted it to do. I had my 10# springs running 18# of boost @75%. I just switched out to 14-16# springs, looking for 25-30#. Trying to do this with out co2.
