Engine stumbles when going to wot
Old May 12, 2017 | 10:46 PM
dannyz's Avatar
Default Engine stumbles when going to wot
Where to look first..
I have a heads/cam/nitrous 2001 Camaro.
Just in the past month it has developed just a brief stumble when I go to wot, from low rpm's.
I just changed out the plugs, BR7ef's, but that didn't fix the issue although the old one's were kinda fouled.
Does not hesitate/stumble all of the time, but rather only when I nail the throttle with purpose.
It does a very very brief "choke", and then moves with purpose.
Possible 02 sensor issue?
Maf? Heck, maybe the fuel filter?
Old May 19, 2017 | 01:05 PM
joecar's Avatar
Try cleaning MAF.
Do you have a PCM log (HPT or EFILive)...?
Old May 21, 2017 | 06:26 AM
stevieturbo's Avatar
Throttle enrichments are always based off throttle movements...is the throttle position sensor etc all ok?
