ls swap problem ( PLEASE HELP ) if you can
Old May 25, 2017 | 03:07 PM
Dag12141987's Avatar
Blue wire pin 24 on the red connector right.
Old May 25, 2017 | 05:23 PM
tsench's Avatar
yes you are correct
Old May 25, 2017 | 08:57 PM
I've been threw just about anything I can think of. Only thing I haven't done yet is seems another ecm out to get flashed to see if somehow this one got messed up. Don't see how it could of. Wish I could figure this out. Even went as far as to removing the ground wires that ground ecm and ran those 4 wires straight to the battery ground. Just to make sure those were 100% grounded.. lol and nothing changed...it's been one of those problems that keeps you thinking. ..and thinking. .. and thinking. . Thus is it. ..NOPE... ohhh now I know... NOPE.. ohh i know what the problem is.. NOPE. . Lol anytime I think that's gotta be the problem it isn't.
Old May 25, 2017 | 08:58 PM
If anyone has had a problem like this or might have any tips or ideas or information that might help please let me know. ... thank you
Old May 25, 2017 | 09:00 PM
pdxmotorhead's Avatar
Have you opened up the ECU and checked for burnt traces? Some ECU's also have a tiny fuse soldered down or a diode that can pop...
Not sure about these but I've found it on other brands...
Old May 25, 2017 | 09:24 PM
Wow. .. no I didn't even think of opening it. . Gonna do that here in a min. Definitely worth a shot . And it's a free and easy try. See. I'm thinking so hard I'm over thinking little easy things like that. Well gonna see what I see and will let u know. ... thank you
Old May 26, 2017 | 06:24 AM
Well opened it up along with another to compare. Didn't look any different didn't see any broken solders or any burn marks or anything like that. And don't have a any burn smell to it at all. So I think I am good there at least
Old May 26, 2017 | 10:06 PM
tsench's Avatar
send me your car info and which scanner you use to read tps voltage and did u get any code
Old Dec 9, 2017 | 09:03 AM
Bkounelis716's Avatar
Angry Same issuee
Have you figured this out? I'm experiencing the same issues. My tps read 100% constantly. Corvette ls1 92 f body
Old Dec 9, 2017 | 11:48 AM
kingtal0n's Avatar
I had the same thing, hopefully you have same issue,
these pictures might help... note accel pedal position is NOT throttle position sensor. Accel pedal is DBW pedal position...
Attached Thumbnails ls swap problem ( PLEASE HELP ) if you can-dbwconversionwiring.jpg   ls swap problem ( PLEASE HELP ) if you can-5.jpg
