180 Hypertech on stock tune?
try to bleed air out (at steam crossover tube);
check for leaks (use pressure tester, detects internal leakage);
check radiator and A/C condenser for airflow blockages;
check airflow deflector for damage.
With the car idling in park she went up to 230. Its 68 degrees outside. Normally driving in this temp it would be around 190. I didn't hear the low speed fan but the high speed came on approximately 225 degrees. The rad isn't being obstructed and the car has good heat. I recently saw post stating the low-speed fans coming on in the low 200s in the high speed fan switching on around 226-230.
I will shortly be removing the factory ps and trans coolers and will install Derale aux coolers. I will also be cleaning the outside of the rad for good measure. I think now these numbers are due to he 187 factory stat and fan temps. They should drop with the installation of the aux coolers. Only the trans cooler will be in front of the radiator so that might help. I think the SLP fan switch could work too but I'm unsure if the low speed fan is operating.
fan-low on=226 off=219
fan-high on=234 off=227
If fan-low is not coming on then that may be the problem... there are 3 relays which control the series/parallel configuration of the fans, see attached.
Thanks for all the infoðŸ‘
