2002 Z28 running rough
He has also added:
92mm throttle body
power force typhoon intake
243/299 stock gm heads
slp under drive pully
delphi 90mm mad
flowmaster American Thunder cat back exhaust
new coil packs
new ngk iridium plugs
meling oil pump
trickflow cam
lifters
rockers
timing chain, cam, and crank gears
Any help would be appreciated
Do you get a flashing CEL when you drive it?
Is the CEL light on at all?
Have you checked the Plugs/Wires/Coils?
What are the cam specs of the Trick Flow?
Was it tuned after the cam install?
