HELP! Engine runs awful after mods and EVAP delete
Best thing would be to get a schematic of wiring & start testing. Pretty sure a 3 wire sensor. Guessing one 12v, one ground, one signal. Good luck man.
So if the reading is the same koeo, koer, at idle & revving there is a problem there. I think you said you removed the intake again & did a good visual, no hole/leak in intake.
What I would do is get a DVOM, volt meter, & start testing the circuits on that sensor. See if you're getting the 5v reference & make sure you're getting the ground. I'm thinking wires may have gotten pinched in the back but just a guess. Visual inspections go a long way. Maybe try & trace the circuits as much as you can.
Not even knowing if this is your "main" problem, the MAP is not working right.
Keep on it man. Post what you find.
