Truck MAF = new tune?
I put a truck 85mm 5pin MAF on my 02. It still has the stock throttle body and stock intake.
Should I multiply the MAF table in my current tune by 85/75 to reflect the greater airflow?
Or is the stock TB going to keep the flow numbers the same?
What should I change if anything? Thanks!
That would be way off if you did that. Multiply the whole table by .85 would get it close, but the easiest thing to do would be to open a 02 Silverado 5.3 file as a compare file and copy the MAF table from the truck tune into your tune. Then from there tune the MAF with A/F error or fuel trims.
3.5 tube vs a 3.875 tube!??
latger tube will lower the MAF HZ and therefore need an increase in airflow
