How to lean out my ls1
someone should ask why your fuel trims are so rich, what did you do to get that way- but I am not addressing that. I am only answering your question directly in the simplest quickest manner.
Have you cleared your trims after tuning? You should always clear your trims when you go to log fueling.
Also, are you logging your VE table or MAF table?
If you're rich in a certain area, you need to lean out that area. No need to change the injector vs kpa table. Quickest and right aren't the same thing.
