tach problems
Old Jul 7, 2017 | 07:08 PM
Go3Win8's Avatar
Default tach problems
i swapped a 02 5.3 into my 79 jeep cj5. i have an old sun super tach 2 it wont work with the signal from the 0411 pcm. tried the pullup resistor not happening. do i need an adapter for the tach, or a different tach?
Old Jul 7, 2017 | 09:46 PM
2xLS1's Avatar
Tach doesn't move at all or reads wrong? You do know that you have to set the tach for 4 cyl engine with 0411 tach output. And you more than likely will need the pull up resistor. What value resistor did you use and how is it wired in?
Old Jul 8, 2017 | 07:08 AM
Go3Win8's Avatar
Tach doesn't move at all. 1000 Ohm resistor wired from the tach 12v to the signal input. on the tach lead from the pcm without the pull up resistor it reads 6.3 volts all the time regardless of rpm.
Old Jul 8, 2017 | 11:15 AM
2xLS1's Avatar
You can't really check the PCM tach output with a meter. You need something that will display a frequency signal like a scope.
