Hypertech knock -can it update??
Old Jul 8, 2017 | 11:28 PM
Ruffturbo911's Avatar
Default Hypertech knock -can it update??
Does anyone know if Hypertech can update a Hyperpac programmer if you are getting knock? Years ago I used the Don Kiger GNX Hi flow chip in a grand national and I understood if I was ***** to the wall flat out which I did not do often I would occasionally get some ping. With octane boost my GN ran great w no ping.
Hypertech is supposed to work with a 93 octane fuel so it should not knock because I only run 93. I know a professional tune is better and probably when I'm done with my car I will have Frost do a tune.
For now I just wanted to use Hypertech to lower the coolant temp which it did great.
I heard that Hypertech can update certain programmers and pull the timing a bit to reduce knock retard which I am getting a max of 2.9. Any insight into this is appreciated.
Old Jul 9, 2017 | 09:20 AM
Why don't you contact Hypertech??
To answer question below: No, I do not have HyperTech.
Old Jul 9, 2017 | 09:26 AM
I will Monday. Just curious if 3.0 degrees KR is common and if they can adjust it. Do you have a hyperTech?
