bigger injectors now lean
I have a 5.3 lm7 with texas speed 2.5 5.3 58cc heads and a 222/226 115+3 .600 lift.
Here is there data site I have the gas vortec 32d-00-0038-8 38lb/hr http://www.deatschwerks.com/gm-calibration-data
Fwiw, a while back I swapped out deatshwerks fir FIC and had to make some tweaks. Wasn't 15% though.
You can do this in your tune and verify it for yourself. Leave the current injectors in and don't touch them. Now, set the flow rate in the tune higher than the data calls for. All your pulse width calculations will get shorter. But, since your actual flow rate doesn't change, the car runs lean, so your fuel trims go up. Then set your flow rates low in the tune. All your pulse widths will get longer, and since the actual flow rate doesn't change, the fuel trims go down.
